Hi everyone, first thx for this great box z8 pro is the beast.
But I have one issue about the playtime limit, it set to 3h, can't desactivate it, which mean if i'm not touching the remote the unit is going in sleep mode, i try other brand of iptv and it's not doing this, i try iptvmate and stbemu and the both not doing it, i know it's probably a setting send by default from the server side, but pretty sure you could disable this setting with a few line of code in a future update. I'm using portal/mac connection by the ways.
Thx
