Help please
- Help
- GTV
Den123 -
August 11, 2021 at 9:05 AM -
Den, you are long enough here to know that this happens also when your provider work on something. Please restart the box or ask the provider if they work now on subs/scripts etc. Like i know your provider, he changes often something.
Sam you know his provider better than he does
Hi Sam. Just found out the portal I had was working fine then stopped have just loaded a different app to see if it works and it worked. So won’t work on GTV but works on app for iPad. Why is this can I do anything Sam thanks
Restart the GTV.
Thanks Sam tried that still same. So just turned off vpn. Then put on nordvpn same. So turned off nord and put surfshark back on next think it all came on brill really strange thanks mate
