z10
  • Bonsoir
    J'ai une formule z10 et j'ai un très gros problème.
    Quand je zappe, ça s'arrête comme si ça bugait puis ça recommence puis tout de suite ça bug et ainsi de suite.
    Je peux le débrancher, le rebrancher, c'est toujours pareil, alors j'abdique je le laisse tourner en rond et le lendemain tout recommence normalement jusqu'à ce que ça recommence à bugger quand je zappe.
    aide moi c'est l'enfer:tired_face::tired_face::tired_face::tired_face::tired_face:
  • check your internet speed seam to me a problem with your speed, you need at least between 10-15Mbps, for normal stream. Download from market speedtest or analiti, it will determined the speed your box have.
    Ca semble un problème de vitesse d'internet, telecharge du market speedtest ou analiti pour verifier la vitesse que ta boite reçoit. Pour la Tv en direct, il faut au moins entre 10-15Mbps juste pour la tv, alors si tu fais du netflix en plus sur un autre appareil ca va tourner en boucle.
  • hello, I have the same problem with my formulate z10 pro max, I change channels and most of them have a spinning wheel and in the end it gives me server error 503 while I have the same server on my z8 pro and I have no problem, and all the updates have been done on the z10, and internet speed question I am at 400mbps down
    Mostly likely service provider issue. Confirmed fixed.
  • Guys, i recommend to all new people here to read first our forum rules. Some are really near to be banned for they recommends!
    Z10 is stable and works fine! If you have issues with your provider, isp,router or configuration + z10, this doesn't mean everyone have same issues.
    I m in holidays in some country with bad internet and the box works just fine without any issues!!
    So, think twice what you recommend. If you send your box back, then stop to post in each your posting what you have done. Once is enough, otherwise its just spam. If you not happy with the box, send back and thank you for your time and effort. Unfortunately not everyone can be satisfied.
