I have tried everything, but cannot get to see the box on my pc. I want to transfer recordings to pc direct. Can anyone please help ?
Thanks,
BEN
Thanks,
BEN
Hi Ben,
Merry Christmas.
I use the software "AnyDesk", it's free, it's works fine for me.
I hope that i have help you.
Irving
Hi Alphy,, thanks for the info. Anydesk works fine, and I can see downloaded files from iptvextreme. I have read that Samba is another easy option, but it seems that this box does not allow it.
SAMBA is yet implemented in Z10. You can set up a NAS in your laptop or PC and save recordings directly in your shared folder.
Create a network shard folder in your PC/laptop (google instructions). Click Network Storage app on the main menu, add server, type in your IP/name of the folder, and click Mount.
Could not get that to work, it said connect fail.
I did exactly like this;
198.162.1.121/pc1/users/desktop/mediaforall/
Is this the exact format, slash lines & all /
Thanks,
Check your folder settings.
Windows: https://pureinfotech.com/setup-network-…ing-windows-10/
Mac: https://support.apple.com/en-nz/guide/mac-help/mh17131/mac
You may want to delete the current folder and start over. Make sure to double-check your IP.
Thanks,
Assuming that link is valid, remove the last /
Thanks,
Don’t use the whole path, you can only use the shared Windows map, I’m using the following format:
//192.168.178.34/movies
When I click on the mount button the connection is ok, I don’t see the Z10 on my laptop but I can reach the movie map on my laptop from the Z10 using a file manager (in my case Kodi)
so if I see this as the full path on my pc, C/users/desktop/tv/mediaforall
then do I just Mount this - //198.162.1.121/mediaforall (leaving out the rest ?
Thanks,
Yes if you share the map mediaforall in Windows and give permission to everyone
Don't forget to Turn off Password Protected Sharing.
Open Network and Sharing Center > All Networks > Turn off Password Protected Sharing
