Z10 Pro Max
  • Hi On the Z10 pro Max Apple Tv is available as an app I can add my account but will not display any of my library but can manually search for a film and play it.
    But no Apple Tv on GTV
  • You could sideload it using downloader app
    get unlinked install downloader from Play store and use code 40869 > unlinked > Go to unlinked store using code 'formuler' > you could see apple tv there and download it
    Once it is downloaded it and launch , go to home screen add it newly downloaded app
    They have recommended side loading it on the GTV, I also have not fully understood why I can get it on the Z10 Pro Max (mobile android) through the Google Play Store but cannot on the box (GTV) that is supposed to be the Google Certified ATV box that I figured would get everything through the play store (minus Netflix). Figured it would have been the other way around with getting it on GTV and having to side load it on Z10 Pro Max, I don’t mind grabbing it from Unlinked Store but seems it hasn’t been updated to current version so not sure how often the unlinked apps will get updated. Thanks all for the info/help I’m sure there is some reason for it but I’m just not smart enough to fully understand it 😂
