BETA firmware for Formuler Z10 Series released.
Firmware Version : 10.10.28 BETA
MYTVOnline 2 : 10.10.26 BETA
WARNING:
HowTo Install:
BETA FW. 10.10.28 and MOL2. 10.10.26 discussions only in this thread here. Other open threads with Beta issues will be deleted instantly!
Change Log
- NEW: Update to Android security patch level March 2022
- NEW: Implement Private DNS. Access from Android Settings > Network & Internet menu
MYTVOnline2 Version : 10.10.26 BETA
- FIX: 4xx stream error when zapping channels from main screen sometimes
- FIX: Portal connection issue after HTTP redirect
- FIX: Stuttering playback after seeking in timeshift mode
- IMP: Add Estonian language to preferred subtitle/audio list
