Netflix on Formuler
  • Hello,
    I just replaced my NVidia Shield by a Z10 Pro Max.
    I'd like have as on the NVidia have Netflix on the formuler, how can I do it ?
    Thanks,
    Update : I installed Downloader and then AptoideTV and then Netflix but any version works on this device :frowning_face:
    Edited once, last by Kris-B (May 19, 2022 at 11:13 PM).
  • Download the version from the Market app located on the home screen.
    Do not update the Netflix app when prompted. Just sign-in.
    Enable mouse mode on your remote to use the app.
    You can map the mouse cursor function to one of your hotkeys from the Formuler Remote app.
    Thanks a lot :smiling_face:
    About the mapping.
    1. Selected the model of my remote
    2. In the RCU Kotkeys menu, I selected app to assign
    3. I don't see any "mouse cursor", I see netflix, Spotify, ... but not this function.
    Strangly I can't exit the RCU Hotkey menu to assign other keys like ".." when I exit the application (via home or back) and I relauch it, I am still at the same place in the remote configuration.
    Any idea?
    Thanks,
  • 2. In the RCU Kotkeys menu, I selected app to assign
    In the Hotkeys menu mark one of 3 buttons with dots and choose mouse.
  • Check the Unlinked Store as well as it seems an updated modified tablet version was uploaded to it and so far had been working pretty good for me even though I haven’t messed with it too much yet. Not sure if that is the same file that is in the Market App but seems like it’s the current best option.
