Hi I have a connection with 2 lines and I use MyTVOnline 2. But when I record and then try to change channel, it says cannot change because recording. How can I fix this? Thanks!
Record one and watch another
- Z8
katedeal -
October 2, 2022 at 5:39 PM -
Which protocol are you using, registered MAC /ID Stalker portal, XC Api with login portal or m3u playlist?
Thanks I use the m3u playlist.
Choose XC Api, its better than m3u,more possibilities!
hi i use 2 different apps mytvonline2 and another on home screen plenty on market
Read thread "Record one channel and watch another" mytvonline2,Z10promax,post#4
Thanks I'll try that!
Hi I can't find that option when making a connection, hoping you can help me. I only see Add Portal, or Add m3u Playlist. (Add Portal is what I use now)
ArticleHow to use MAC/ID portal, Xtreme Codes Api (XC) and M3U Url on Formuler Boxes.
IPTV Connections
SAMMay 24, 2019 at 2:54 AM PostRE: Record on 1 channel and watch another or using PiP
With Stalker subscription is…
SAMJanuary 19, 2021 at 7:58 AM Create new m3u playlist with your old data and at end when MOL2 ask you if you want instead use XC Api portal, just say yes and MOL2 creates xc api portal with your m3u data.
I can't see that option. Do I have a different version?
The easiest way of changing to XC-Api connection is to contact your IPTV provider and ask for URL,username and password you can fill in these data in the upper Portal.
On the other hand if you already have username and password you can follow the guidelines as described in the article "How to convert long m3u to XC API Portal" You can find this in Formuler Helpdesk in the section find a solution in the section Tips and Tricks.
Same is in forum article included, he need just to read.
Other way:
1. Create new portal
2. insert the url address, end should be .com
3. Click on login requered
4. Insert your username and password -> connect.
5. XC Api Portal created.
Video (Method 2):
External Content www.youtube.comContent embedded from external sources will not be displayed without your consent.Through the activation of external content, you agree that personal data may be transferred to third party platforms. We have provided more information on this in our privacy policy. -
Thanks! I'll check out these guides.
It works guys thank you!
