Z11 and Mol3 Bug and issue reports
  • Please I really don't need examples, I own a Tesla and there is many niggles I have with that but the good outweighs the bad. If you jump on day one and expect a product to be perfect I'd suggest you have not got a realistic view of products over the last 20 years. I've a qnap 5 bay Nas drive that is over 2 years old and still being fine tuned by qnap and that's a fair chunk more than a £170 product.
    I dont need perfect only the basics. live tv and Epg. All the extras will come later maybe...this time good doesnt outweights the bad because the basics doesnt work properly. We will see when it wil gets sorted.
  • So got my delivery today of units and set up my z11 pro max, initial thoughts are bit mixed as epg does not clear at all for guide etc but when you bring up info and press right the info is all there. Can you advise when this will be fixed as I have substantially commited to this box both pro and max and a guide is pretty much a must. Have a GTV, Z10 and Z10 pro max here on the same provider and all clear guide perfect. Have tried deleting and refreshing epg to no avail and also deleting portal and readding.
    Please check your PM and reply to the message.
  • Hello guys
    Let's say that I want to watch a TV programme from yesterday. In order to get the app setup to let me show that actual programme, I have to select the tv-programma that start before the one I would like to see.
    There's no timeshift set in my device and also not in MyTVOnline3.
    This bug started at the same time that the clock was set 1hr last weekend. Here is Holland we do this because of summer- and wintertime.
    Can someone explain me how to fix this?
  • After Shut down, I can't start it with the remote, I have to cut the power for it to start. Stand by works fine. Tried reinstalling, same thing happens. Should I send it back, or is it a software problem?
    20221103_133010
    streamable.com
    tracking# CA23F3
    Edited 2 times, last by p.b (November 3, 2022 at 1:51 PM).
    Please provide a video that shows the exact issue for further investigation. You can upload the Image/Video file here: https://streamable.com/ > Upload file > Copy link > Paste the link with your reply.
    Also send logs right after the issue reappears following the next instructions: How to send logs
  • In VOD/Series, newly added VOD is displayed by default or can be set using the sorting function.
    Please check again or compare with MYTVOnline2
    I am on about the section called NEWLY ADDED, this is not sorted by newest first, which is a shame as you need to scroll right to the end to see newest stuff which is plain stupid
  • Quick question, I’m on Z10 and thinking about the Z11, how are you Z11 users experiencing the product as of now? Not quite sure if I should wait a bit until things get more stable as I’m enjoying the Z10 and don’t want to make the switch if it brings down the experience.
  • Don't worry to much about the initial hickups with the Z11promax,why don"t enyoy the experience with both of them.I intend to sell my z10pro,in a few months,as the Z11 will be stable
  • When I try to go from one provider to another (I have 2 lines) I can't do it on mytvonline. With the gtv I went to calls and turned off one to activate the other, in this new mytvonline I can't find the connections. If you do leave it leaves, but does not turn off the provider. Z11 MAX PRO Help please
    You don’t need to disconnect from one provider to the other in this version.
    Once you’ve added your connections, you can view all information in one playlist
    Example:
    You’ve entered connection (A) at setup and also connection (B) at setup
    When you open MYTVONLINE3
    Go to your TV channel listing and you’ll see for the groups
    Connection (A) list is first and as you scroll to the bottom of that connection (B) list appears
    Also when you’re on connection (A) and watching a channel, if you press the info button on your remote, at top right of the screen it will show the provider name you entered so you know which connection you’re on. Assuming you didn’t know already.
    Same with vod however it will appear at bottom right showing which connection you’re on.
    To setup again or edit connections
    On any channel press menu button on the remote
    From the drop-down menu go to content manager
    Select content sources
    You can view / add / remove from there
  • Tks my friend
  • I cannot get my Mac subscription to populate all the channels on my Z 11 I put a message up yesterday. It was working fine on my Z 10 now it will only populate a few of the channels. It is not being used on any other device. The other device was logged off correctly and wiped clean, not sure where to go from here suggestions please
  • Hi.
    I run 3 providers on my new formula z11 pro max.
    I like the way you don't have to change portals anymore but I think a folder needs to be added so you can select what portal you would like to view the channels on ?
    I understand that you can create groups but then this still leaves so much to scroll down and find what I want to watch.
    Thanks Dan
  • I run 3 providers on my new formula z11 pro max.
    Is already requested and forwarded to Formular as future request. Switching IPTV providers
    Any idea when config file option will be available for the z11 ?
    Is not implemented yet, will take some time (Bugs have priority) and no date for this.
    I buy z11 pro but is not working correctly, when I put the portal only appears 14 channels, in formuler z plus the same portal I have 400. Someone can help me to fix it.
    Please post more detailed infos about your Portal/subscription!
    @All
    If Bugs or Issues are reported please post each time what is in use, so we have more infos to understand what`s going on.
    1. Stalker MAC/ID Portal
    2. XC APi Portal
    3. or M3U Playlist.
  • Series history isn’t showing anything despite us watching something. When I then search for what we were watching it doesn’t show a progress bar up to where we were in the episode either.
    I can recreate this fault.
    If I am watching a series episode, and I press the hotkey ii which is mapped to go to live tv, it forgets I was watching. This is repeatable.
    I have three portals with username and password and the latest updates on the box.
  • I have Stalker MAC/ID Portal
    VOD and Series TV is working good.
    Categories appears all groups but don't have any channels, only the group Adults have 14 channels.
    Turn off MOL3 or reboot your box. Reopen the app and go to Content Manager > Data Sync > Contents data and click Refresh.
    If channels don't come back, please send logs right after the issue reappears following the next instructions: How to send logs.
    May need additional information. Will send you a PM if the issue remains.
  • My connection on my Z11 pro via vpn surfshark is very slow. It is more than halved. The funny thing is that there is hardly any delay on other devices with Surfshark. And when I turn off the vpn on the Z11 pro the connection is fast again. Is the problem recognizable and does anyone know a solution.
  • I am using 2 portals but after a while the portal in second position stops and I have to restart it manually via the content manager.
    If the screen saver is activated, it starts during VOD or Series, it's quite disturbing, on the other hand, in live tv, everything is fine.
    It would be nice to have for each portal a separation in the list of channel groups.
    Could be the IP change. Take a video of each situation and post it here. You can upload the Image/Video file here: https://streamable.com/ > Upload file > Copy link > Paste the link with your reply.
  • VE and JD, i also are exploring my new z11promax,i am mainly focussing on live tv,so i do not have an answer to your question.
    Don"t forget to mention in your posts on what Protocol your on (MAC/ID,XC or m3u) and wheter you have multiple subsriptions.
