BETA FW. 11.1.40 and MOL3. 11.1.59 for Formuler Z11 Series
  • BETA Software Update for Formuler Z11 Series devices.
    FIrmware Version : 11.1.40 BETA
    MYTVOnline 3 Version : 11.1.59 BETA
    WARNING:
    HowTo Install:
    BETA FW. 11.1.40 and MOL3. 11.1.59 discussions only in this thread here. Other open threads with Beta issues will be deleted instantly!
    Changelog:
    • FIX: Auto shutdown message after device boots by TV CEC command
    • FIX: VIsibility issue of unsupported audio codec
    • NEW: Playback player UI
    • IMP: Added OSD translation for multiple languages
    • IMP: Universal Search optimization
    • FIX: Unable to display program registered in Watchlist in Watchlist group
    • FIX: Unable to display image file attached to Notification messages
    • FIX: issues from refreshing multiple playlists
    • FIX: VOD & TV series menu missing from the main menu
    • FIX: "Failed to load VOD data" error
    • FIX: Unable to load VOD media data
    • FIX: Duration issue with scheduled recording
  • Hello,
    feedback on this beta version: I thought that the bug on the fast forward of the replay was solved to my great surprise new players... but problem not solved or even accentuated since it is no longer possible to quickly move forward or backward on a vod strongly a new update
    thank you
    Edited once, last by glfred (December 5, 2022 at 3:30 PM).
  • Please read the first post of this thread highlighted in red...
    so description of what was done and corrected by the post above.... be patient, programmers are human beings too and there are more important tasks than yours...
    P/S And you don't need to enlarge the font, there are no blind people here and everyone can see everything.
    forum reader
  • Hi,i do not see epg issues mentioned in beta update,is it better for me to await the final update?
    Please advice!
  • Hi, on the other hand with this update it has made it possible to put the mol 3 menu in French but for the physical keyboard I still put the French language as on my z10 and the keys do not correspond, what to do? ??
  • Thank you for the good work, I updated successfully the Beta.
    I would like to report two issues:
    - EPG appears correctly when clicking on Guide, or right click the cursor, however in the full list of channels I see (no information).
    Each time I need to go to guide and I see the epg there.
    - There is black background for subtitles... When I try to fix it from caption (accessibility), the black background is not going away.
    I love your products and you got one of the best BOX in the market (Z11 pro max)
    This issue is reported and being fixed.
    "No information" in EPG and Subtitle background color issue are being fixed.
    Currently, only the Captions style function works (white on black, black on white..)
    Custom Features are not available.
    Please wait for the next update
    Easy fix would be to replace the default VOD player in Mytvonline3 settings to another (better) one.
    MX Player Pro will do a good job with its default settings and get rid of the black background annoyance. Also very useful for audio and screen formats and... caption styles!
  • Easy fix would be to replace the default VOD player in Mytvonline3 settings to another (better) one.
    I will try it, thank you.
  • Since I installed the latest BETA I got an error I didn't have before.
    When I watch one or several different channels and then go back to one of them and press the remote control, it shuts Mol 3 down and I have to restart Mol3. (sent log)
    (Using extreme code.)
  • Good evening all, so my feed back with the beta in general similar to those mentioned.
    It did fix my missing vod and tv series.
    Improved the epg massively, still som no information, the epg populates much quicker though.
    No fast forward or reverse on catch up.
    That said big thanks for the continued support and time investment in getting the software sorted
    Please check PM
  • Hi
    Not sure how it was before, but how can we check on Favourite VOD (Movies and Series) the provider? Or am I missing something?
  • Hi,
    Once the Beta become stable (official) do I need to install again the stable?
    Once I update to beta, will it update automatically for new version in future, or I need to always do it manually?
  • 1/no
    2/do manually,most of times,if new official update
  • Once the Beta become stable (official) do I need to install again the stable?
    No and you must each update in future accept/confirm manually otherwise the update will not install. Like always.
  • the official update just arrived after the update I worry about the channel list is still not fixed it would be nice to have a complete list and not a cut channel list. on the list of 1 at 10 super but from the 2nd page the chain 7 and 17 its cut.
    picture attached
