Been an annoying issue for some time. In the channel list it shows No Information. When I press the Guide button the EPG list is correct. Why is it not showing in the Channel List. Works on Z8 and Z10 but not Z11. Pictures attached
Channel List No Information - EPG has info
- Z11 Pro MAX
- MYTVOnline3
bigbadger51 -
February 18, 2023 at 12:25 PM -
Hi,BI, it seems you are describing a similar issue as in the thread EPG not working correctly,by Eddy51.Have you read this thread,and maybe you can comment on it there as well?
Was reported and in check.
That's in
That's intresting cause I'm seeing the total opposite
That's in
Your first picture looks like you are in the Catchup Screen. I am interested in obtaining the Information in the standard Group Channel listing.
I hope the developers are able to fix this EPG issue soon.
I have now also traded in my second z11 pro max, number 3 will arrive tomorrow
1/the first cannot record for more than 18 minutes..then the recording stopped
2/the second was super for 2 weeks
and then I could no longer watch a vod series and no longer watch a program back in time
and this while my Z8 on the same account can do it all
I have already factory reset it 3 times
I suspect the problem started after an update
