If i restart/shutdown the Formuler Z10 Pro Max, MOL2 autostart and the portal does not connect if the connection is the Ethernet cable (message: still waiting for connection). To bypass, i have to close MOL2 and restart the application and it connects. There is no problem if you use wifi.
I have also the Formuler Z8 and this Ethernet problem does not exist (with the same Ethernet cable).
I saw there was a fix in the last update, but it didn't work.
I have already reset the box, activated or deactivated the ipv6 did not work, only works for the first time with Wifi.
Thanks for your help
