When I’m tethered to my iPhone hotspot and using MyTVOnline3 on my Z11 pro max I’m unable to watch live tv and get the following message “an error occurred: ParserException”, regardless of the strength or speed of the connection. If I connect to a Wi-Fi connection it works fine but is obviously limiting where I can use the service.
Everything else works fine, VOD, TV Series and catch-up. Is there a setting I need to change to sort this out? I can watch the same content without problem on a smarters app which would point the problem away from the provider.
