MOL3 and VPN integrated
- Z11 Pro MAX
- MYTVOnline3
relu -
July 19, 2023 at 3:26 PM
use vpn through the router if supported or install client on the box.
some service may be more compatible than others or require extra settings for best function.
mol main function is iptv so don't think vpn client will be integrated into mol itself.
Alright, thanks
So no VPN in MOL3 planned
OK> opnevpn works fine
> I don't want to switch reuter vpn -
For VPN are external apps or Router responsible and no plans to include something like you requested.
If you must use net.openvpn.openvpn try to setup Split Tunneling on the ovpn server:
Split Tunneling With Access Server | OpenVPNHere’s more information on what split tunneling is, why you would want to set it up, and how to do that with OpenVPN Access Server.openvpn.netor
You can try https://play.google.com/store/apps/det….blinkt.openvpn and setup the VPN to on be used on specific apps.
This should preserve the connection to your local network resources.
Be aware that de.blinkt.openvpn is not 100% optimized for TV user-interface and you might need to use the mouse cursor to navigate the app.
