First post so please bear with me if I'm in the wrong place etc.
Want to install a VPN on my box but can't find any how to guides or recommendations for one that works well with the box.
Any help really appreciated.
Go to Homepage and install your VPN from Market,i use NORD vpn,and its relatively easy to use and works well on Formuler boxes.
Of course you can also use Expresss or Surfshark,just try them out!
I use also nordvpn. Its one of the fastest vpn. Simply to use.
surfshark and expressvpn i heard they are also good yes. But i didnt try them cause nordvpn is good enough.
I use Surfshark and I find it to be very good.
I will try one of them now and see how it goes - thanks folks
I use Surfshark as well. Woks fine!
Loaded Surfshark yesterday and all seems ok, I'm in Spain.
From time to time I suggest a speedtest and if necessary simply switch country. Surfshark has a nice feature where you can actually see the level of occupancy of the servers for the selected country.
After every (re)start of your device the app nordvpn searches for fastest server.
Surfshark should do it also i think
I use WireGuard installed on VPS €1 month, it works very well.
Hello
I have 2x Z11 PRO MAX at 2 different locations, lets say LOC1 & LOC2. both latest version and connected via ethernet, rebooted after installed surfshark
- when I launch surfshark at LOC1 (LOC2 power off) - sometimes i have no issue, sometimes no picture/sound on myTVonline3. no problem when surfshark disconnected
- when I launch surfshark at LOC2 (LOC1 standby) - no picture/sound. solved when I disconnect surfshark
setting surfshark : fastest location
any idea ?
Good morning I needed your opinion, what is the best VPN for IPTV? NordVPN or Surfshark? thanks
Display MoreHello
any idea ?
What Protocol are you using, if not already try wireguard also try different locations start by the ones in your own country.
Is it a paid version of surfshark, free/trial versions may have limitations.
I am running surfshark on my Z11 Pro Max and I have none of the problems you describe.
Can not advise on nord as I have never tried it, I use surfshark with no problems at all.
What speed do you have for Surfshark?
Line Speed is 1000mps with surfshark speed is 791mps
NordVPN is also Top, works very good in my tests and on used Boxes.
thanks for reply, i have the paid version and use wireguard on my own country
All I can suggest now is to try the different protocols to see if that helps.
my line speed is 1500mbps but with Surfshark all I get is 260-325mbps such a loss of speed
Its normal.
Vpn is always slower.
Got nordvpn and did speedtest. 600mb and second time 877
