I have a Z10 pro max running mytvonline2, about a month ago I started getting a black screen,
The portal loads but then I get a spinning disk and it says please check your Internet connection (0) a network error has occurred.
I have an ethernet connection (via a tp link),all the other apps working fine.
I have installed Tivimate used the same portal settings it works fine, I have contacted my provider thay have sent new settings exactly the same.
The strange thing is if I press the guide button with mytvonline2 it shows me all the programs and times thay are on, looks like the epg is loading but no picture ore sound.
I have factory reset my Z10 pro max (the same), uninstalled and reinstalled mytvonline2 ( the same no Internet connection (0) ),
I have reset my router, gone into settings made sure made sure it is set to DHCP,
Has anybody else had this problem
