Hi, I have problems with my Formuler Z+, Market not work, FreeTV and youtube not working at all... I cant enter Market, there aren't any apps
Market and other apps
Hi, please do factory reset, seems on your side is something more wrong than just some setting. Clear all and set fresh, this should help.
I did everything, but nothing to help
Again, do factory reset like here -> Factory Reset after firmware 1.2.71 and newer
After successful factory reset check first if your box have internet connection and reply. I checked few Minutes ago with same box, Market is working.
I did factory reset, my box have internet connection, but Market not working, empty all
In market write ''Can't connect to server"
Do you have any way, to solve my problems?
On your picture you chose User Market and for user Market you need code. The second Icon is Formuler Market, that should work.
The second Icon, Formuler Market not work, I don't understand why
CodeIt's not true, I have the same problem, it doesn't read the USB, it doesn't have access to the Market. Ap version is contradictory. My version of the application is as follows, v2.0.18-r2728 Correct?.2.71 and newer
Is it working? I don't believe anymore
Tested again and yes the connection with server is now not available. Is forwarded to Formuler.
Please test again tomorrow.
But it is more important for me, I hope tomorrow will be working
Like i say, it is forwarded and reported to Formuler!! Please be patient and await until it is again online.
Z+ is a legacy model and the software support is deprecated.
I recommend you purchase a new Z10-series or Z11-series Formuler device.
The new MYTVOnline2 and MYTVOnline3 software are huge improvements over the original MYTVOnline.
Also Z+ is running Android 4.4 operating system. Google has stopped supporting this OS for a long time and new apps are not compatible.
Use User Market for now -> 0852
not yet
Now Market is open, but don't download any apps..
Why SAM you closed my thread? My problem have not solved, not working Market at all
Before you ask me such things, please check first what happen last few days!
All older Boxes (Z prime <-> Z7+) changed status to -> Legacy Devices (end of support)
Therefore all threads in this forums become status closed threads.
Your Box use deprecated Android 4.4 and most Apps need higher Android OS version to work properly.
