Just recently bought a new 75 tv and the quality on forumler z8 pro is terrible the motion with the ball is horrendous also ball disappears when it gets kicked, I used the exact same settings on box when using a 58 tv and I can’t say I noticed issues (maybe just because it was smaller)
I’ve read some calibration settings to try, is the motion settings normally as default set as on? I didn’t even know there was this menu rather than the basic display menu on the box itself, there also seems to be a slight stutter on this tv, as far as I remember the top setting on display settings says 1080i and resolution is set at auto which is 4k 60fps
Any ideas on fixes? I have kind of ruled out it being the tv, as when I went onto YouTube through the tv and watched a 4k game the motion on the ball was absolutely fine, any tips appreciated cheers, played about with tv settings and some did improve it but then made other areas worse
500mb internet, hdmi 2.1 cables (I understand won’t be 2.1 quality)
