Box has just stopped working.
We have no light on the front. Nothing.
Can anyone suggest anything?
Died suddenly
- Z11 Pro MAX
- Hardware
gasman -
June 19, 2024 at 7:36 AM
hi
Did you try a hard reset?
If it's a Z11 -> https://support.formuler.tv/kb/article/198…ro-max-z10-pro/
If it's a Z Mini -> How to factory reset Z mini
Replace power supply and test again.
The power supply has 12v coming in from the box connection side.
Yes, use other power supply with same specs as Formuler`s and test again.
Yea, exactly the same. No life at all 🥺
My condolences for the loss of the box
What’s the warranty on these boxes?
Dont know for sure. 1 or 2 years?
Depends very much on (re)seller or bigger companies like Amazon and Bol.com,may range from 3 months to 2 years
