Did you try to set buffer to long?
Official Update - Formuler Launcher v. 12.1.4 HOTFIX and MOL 3 v. 12.1.4 HOTFIX for Formuler Z11 Series and Z mini released.
- Z11 Series
- Update
SAM -
August 6, 2024 at 7:09 AM -
Have it since a week.
When i put it standby and later on.
Then the imsge is stuttering. When i zap itsover?never had this before
Thanks for the suggestion. I just tried setting buffer to long, but still having the same issue. It's strange that it only ocurs with the 24/7 channels. I still think it's a provider problem but I'm going to install Tivimate later to hopefully eliminate MOL being the problem.
I'm not sure if this is Formuler related. Am curious if other users are having signal strength issues. I suspect it's a provider issue and have contacted them, multiple times. Naturally, they say all is fine on their side.
I've started to have a problem with the signal for certain channels, specifically all of my 24/7 channels. The signal will have three full bars in MOL then start to drop after a few minutes. If I restart my Z11 Pro Max, the signal is three bars again but starts to drop, causing freezing/stuttering. My Z11 is connected via Ethernet and I'm getting 800-900Mbps download speeds.
MOL 12.1.4
Hi
I have the same problem, loss of internet on mol3 appI'm on cable all the time, I tried wifi and I have the same problem
I did this tests at the time of the bug
Speed test very good result more than 900 mbps
Test directly on my lg tv with an iptv app (smarter pro) without using the box formuler z11 pro max everything works perfectly does not come from my iptv provider
On my box I have only a speeds test app and the box's bass apps
Test with Cloudflare as DNS Server and report back.
I just tried with the three DNS options (Cloudfare, Google, Quad9) and still having the same signal issue. I'm not sure how to try it without using the Z11 box. I'll need to figure that out.
Contacted my provider again. They still say all is fine on their end. I signed up for a trial with another provider and am waiting for credentials to try it out.
Since the update i had some problems with playback of scheduled recordings.
I have set extra recording time at 3 minutes,and got used to fast forward playback of the recording,to the actual starting point of the recording,this resulted in stuttering and frequent short repeats in the recorded show.
Tonight ,for the first time,i did not fastforward but let the recording playback from the real starting point (-3 min),and to my surprise the issue was no longer apparent.
Anyone else noticed this,or has a plausible explanation?
Received notification of new version.
IPTV v12.1.14
Nothing happens at start Upgrade.
What is wrong?Tried again and then it worked.
Hi,just updated to last IPTV version
In Game day i cliked on Premier League,todays monday match event,says fail to load data,data on the monday night match not uploaded yet.?
Will try again in a few hours,thx,Game day is great tool!
Updated this morning direct. So far so good. Didn't test the game day cause i dont like sports so much.
But i give it a try tonight.
In Game day I clicked on Premier League
Getting the response "Failed to load data"
What is wrong? -
What is wrong?Nothing dramatic,the data for the monday night Premier League game are probably not uploaded yet.
Not being a big sports fan I had a quick look to see if I had the same results got no results for football, but I did get results for baseball and American Football.
What I have noticed is a long time to change channels get either a black screen or still from last channel watched.
