Hello, since the update on my Formuler Z11 Pro max, I have the problem when I want to watch a trailer that I always log in after the Formuler is disconnected from the power, that Youtube requires a login, even though I did it a day before. After logging in, Youtube also works perfectly. Only when switching on for the first time does he repeatedly ask for the login. Has anyoneDoes anyone have the same problem or a tip as to why it is?
Youtube Login problems
- Z11 Pro MAX
- MYTVOnline3
Bangerbln -
August 30, 2024 at 8:47 PM
I have the same problem after changing my Google password. No answer yet.
Use SmartTube.
Use SmartTube.
Smartube doesn’t work for vod trailers
It should work if mytvonline3 get option to select "other app".
Just like the vod setting where you can setup internal or external player.
Ontopic: please wait for youtube answer. Its on there side.
Would be nice but can’t see it being a priority, as YouTube app works fine for trailers.
Only benefit to smarttube for trailers is no adverts
