I’m having a lot of lip sync issues with my z11 pro max connected to my denon amp at the moment. I know there is the option to adjust the audio delay which does work, but I’m having to constantly adjust it all the time. When going from live tv to vod, vod to series or even between channels. Have been using a Z8 for years previous to this and I never had these kind of issues, it’s the same provider all along so I’m wondering if it’s a z11 issue? Driving me mad
Audio Sync Issues
- Z11 Pro MAX-BT1
- MYTVOnline3
Tpj -
October 13, 2024 at 10:54 PM
I had the same issue on ocassion,and the tip i got from adrilang solved it for me;
Simply restart your box once.
Still having this issue with the sync. Have to manually adjust the audio sync every time I watch vod and it’s always a different delay, sometimes it’s ahead and sometimes it’s behind.
Are you connected to any soundbar/sound systems?
Yeah it’s connected to a denon amplifier, the tv is connected via Arc
Edit: Forgot to mention also that pausing the movie or stopping starting it will sometimes improve the problem, but this means after a pause I’ll often have to adjust the sync all over again having got it right
Also downloading kodi and using it for the video player the audio is then in perfect sync on the same files. I would much rather use the MOL 3 built in player though . For one, using kodi through mol3 the videos do not resume from where you left off. -
Same issue for me
Z11 pro max
Very annoying -
Same problem here.
