When trying to use downloader app .I get athe message as seen in attachment .is there a way to fix this please?
Downloader app
- Help
- Z7+
Mikeb100 -
October 30, 2024 at 7:38 AM
Hi
I am having this same problem. So is it the device is outdated to use downloadee app?
Hi
I give it a try and look for a fix.
You all use z7 (5g)?
Also z8 had also same android 7.
Hi
it could be m8, as i tried to install PIA vpn on my m8 Z7 and it told me the box is not compatible
Pia.is minimal android 7, so should work.
Maby you download the mobile version.
Will have a look for you for androidtv version
Ok thanks guys. 👍
Hi
I am having this same problem. So is it the device is outdated to use downloader
Yes mine is a Z8 I think but it's on Android 7 and there's no updates available any longer I don't think. Thanks a lot.
Sorry,
If i backup i got only apks files and not apk.
If you install an apks installer it should be fine.
Got also modded express vpn and after 30 days trial it still works. Thats an apk.
What you whant my friend.
Goodday.
Hi
Thank you
Did you manage to get it to work is that what you mean? Is there a name for an APK installer ?
Hi
Thank you
Yeah, something like apks installer
Ok but can you put a code for an app like it downloader. Whet I mean is I have codes to use in downloader but how can I get them in APK installer?
I try to get a copy of an apk. But its very difficult. If i can make it happen is sent it to you my friend.
Private internet right?
Ok thank you so much yes it's my own home internet.
My bad,
I mean you want the app private internet access right?
Its also in rhe formuler market.
Did you try that one to download my friend?
I can sent you a version of expressvpn.
Didnt test is cause i got nordvpn.
But if you sign up on that app.
You got 30 days trail.
Try download pia from playstore
So even the Downloader app in the Formuler market doesn't allow me to download anything. Still coming up "check URL and connection" . I think the android version is too old. 😏
Do you have a formuler z7 or z7 5g?
If yes, check direct your pm what i just sent you.
You find your pm here: https://www.formuler-support.tv/conversation-list/
Any luck with the PIA m8 cheers
Not yet, try first from market
yes i think it was on Market m8, but would need to confirm that for the z7 box
Pia is for android 7 and higher.
So you can install it by playstore.
Formuler Z7 and z8 do have both Android 7
i will need to go back and look at their box, but i did try to install it m8, but no luck, but will go back and look at his box again to see whats what thanks
Why do you need to go back?
To have a look or pia is in the narket on there z7?
I have also z7, so i can also have a look for you. If you that mean.
lol... its my m8s box, so need to go to his home, and recheck his box m8...thanks
Oh so. Im not fully wake😉😴😴😴😴
Or do a videocall. 😜😂
Pia / private internet access is not in the market of the z7. That what is just checked.
So playstore
Having the same problem with downloader on my Z Alpha
