Codes not working
  • All of a sudden, new portal codes aren't working.
    It's the same thing on more than one that I tried, all the codes are right...then it stays at 0% for a little while, then goes to 5% for a bit....then bombs. This sound familiar to anyone?
    Please help me out here. I've about had it with Formulers I'm gonna go back to cable or something...I've had constant issues. It's not worth the few bucks i'm saving.
    Edited once, last by shiloh (November 10, 2024 at 2:27 AM).
    You mean portal urls?
    You bought subscription for tv?
    If it doenst come further then 10%, the url is not correct or username or password.
    So it works on my side, why not on your side? Can be anything.
    Mostly end user things, like wrong url typed or internet problems etc.
    Dont blame formuler if its not working on your side and on other side it works well?
    Give us the right info on forum and we can help you.
    Are you xcapi, or macid connected?
    If you dont know the difference already, dont say your done with formuler😉
    Do you use vpn? Etc.
    We will help.you, give us detailed info please.
  • My Xcapi codes worked for a day, then stopped again. The portal names have an x by them in the content manager. Other functions work, I have a show I recorded that I can watch fine. But not streaming. Any ideas? I did a soft reboot, Turned the wi-fi off and back on, disabled and re-enabled the portals,....I dono.
