MyTV Online3 shuts off automatically.
  • I have it sometimes.
    When I start the box....come in home.screen and start Mol3 immediately.
    Then it plays TV for half a minute or so and then shuts and goes back to home screen.
    Then I cannot restart Mol3 or any other app.
    Have to restart the box.
    If a wait a while(half a minute or more) in the home screen before starting Mol3 the issue never occurred.
    Last time the same with a quick start of the Spotify app.
    Maybe the box is still busy starting up things and therefore shuts down.
  • What happens if you set mol3 as starting app?
    The box should immediately start mol3,bypassing homescreen,as it is in my case,from mol3 directly into live tv.
  • I get the sudden shutdown occasionally, but not in the same you do, my box could be on for hours before it happens.
    like you I can not start any apps after it happens, but I find if I go to settings (the cog item top right) select sytem info then without doing anything go back to home screen and I can restart MOL3.
  • Sometimes when I go to mytvonline 3 and i im on live tv it close and when I select mytvonline 3 Notting happens. So I must restart the box and it works.
    If the issue is reproducible, please refer to my reply to the original message above and send logs.
  • Thank you for your reply. Here is the tracking #: 0000001818CB3 of the log per your request. I also believe I have resolved the issue (at least for the time being) by manually refreshing couple of times the “contents data” , “update epg”on the Z11p max box although I don’t understand why i had to do so when the “Auto Update Setting” should handle this automatically without user’s further intervention? See attached picture for reference. May be I am not clear on these features so hope someone can explain.
  • If the issue is reproducible, please refer to my reply to the original message above and send logs.
    That's the thing.
    I cannot say it is reproducible.
    I also made it a habit to switch on the box....then do a couple of others things and then start Mol3. :grinning_face_with_smiling_eyes:
    I will try starting immediately a couple of times.
    At the moment I choose Mol3 as startup app as suggested by Henkie.
  • Yesterday using Mol3 as start up app.
    Watched El Quatro without shut down and also without roll backs or freezes which happend a lot in the past in between 21:00 and 22:00
    I will test more and then go back to the situation where mol3 is not the start up app.
    Will report later.
  • Hello i got one like this, Z11 pro max, what i did was, do a soft factory reset, from the menu of the box, but still the same, Mol3 keep on stop, after that i tryed unistall Mol3 , and that solved the problem for me, i clean cache , before uninstall, i go to market to download, and that resolved the problem.
    hope this helps you guy´s
    Thanks for your info. Hopefully users help it.
    Strange that after software reset it isnt over and after uninstall and reinstall its over.😃
    Software and electronics still always Be strange with fixing some things😂😃
