Can anyone tell me how to reset my Formuler Z11 Pro Max to factory settings?
Factor Reset
- Z11 Pro MAX
- MYTVOnline3
j5281 -
January 3, 2025 at 3:30 PM
Formuler Home Screen
Settings > Device Preferences > Factory Reset -
hi
or take a look at eg SAM's post #2 here -> RE: White light does not com on
Thanks for your help. Unfortunately, I keep getting an error so I can't even get into Formuler. Is there another way to reset?
I keep getting a message saying I'm not connected to my WiFi but I am and the signal strength is Excellent! I am totally confused!!!!
Hi,is there an question mark or exclamation mark over your wifi icon?
Have you tried switching both router and box off for a few minutes and then fire them both up again?
I did a factory reset and everything is working great now! Thanks for your input
Good choice. Everything fresh again. Goodday
