Network Storage does not reconnect if the connection is interrupted by VPN or network issue
  • I have the Network Storage set up on my device and it is working. It connects on startup and I am able to use it as a storage location.
    However it will disconnect when I connect my VPN and it does not reconnect unless I go and manually connect it. I've also had my NAS reboot which causes it to disconnect and it will not reconnect unless I do it manually.
    Is it possible to have the Network Storage retry the connection if it disconnects? Perhaps a feature request that it should retry the connection until it succeeds?
    Thanks.
    • Model: Z11 Pro MAX
    • Retail Box or Provider Box: Retail
    • Firmware version: 11.3.5
    • MYTVOnline 1 / MYTVOnline 2 version: 12.1.20-4552
    • Box connected with: Wired
    • What issue(s) are you having? -- Network storage disconnects and does not reconnect
    • What was you expecting to happen? -- Try to maintain connection, reconnect if disconnected
    • What happened instead? -- Network storage stays offline if connection is interrupted
    • How can we reproduce the issue you are having? -- Disrupt the connection to the network storage temporarily
  • Mostly connection issues over VPN are DNS related. Adding the IP and server name to the Hostfile is the quickest fix, Try connecting using the server’s IP instead of name and do an NSlookup to see what the computer using VPN is getting as DNS server.
  • I'm using the IP to connect to the network storage. The formuler box is disconnecting the network share when the VPN connection is enabled on the formuler box. I believe the issue is the network storage feature on the formuler box disconnects because the VPN connection is established.
    I guess this is more of a feature request for the formuler box to reconnect the network storage, or maintain the connection if the connection should drop.
  • I'm not using the host name.
    I'm connecting to a local network share by IP address.
    The issue is when the connection drops it needs to be manually reconnected.
    I believe the confusion is you think I'm using the VPN network wide but I'm only using it on the Formuler box with the Android app. It does not affect the rest of my network at all.
    Sorry I should have been more clear on that.
    -- To explain further, take the VPN out of the equation. Not using the VPN. When the server hosting the network share reboots, the Fomuler box drops the Network Share connection (as expected), but it doesn't reconnect until I manually reconnect it.
    Same issue, as the VPN on the Formuler box is essentially re-establishing the connection to my network, which drops the Network Share.
  • I have no issues with my server or my network share. I have an issue with the Formuler box not reconnecting to it when the network is disrupted (enabling VPN on Android) or when the network connection is lost (cable unplugged and plugged back in to Formuler) or when the server hosting the share reboots.
    I do not need to troubleshoot my server.
  • It's a SMB network share on a Windows Server.
    VPN is Proton VPN and I have tried with Split Tunneling on/off.
    Same here.
    Have a raspberry pi 5 with openmediavault nas software.
    When i connect manual its okay.
    But after restart and boot up it says. "Connected to nas" and then "disconnect to nas".
    I uninstalled my nordvpn completely and then issue was over i thought or it was not🤔. (Will test it later for sure) so i can make it hard.
    I added at splittunneling ALL apps for test and also same issue!
    Its smb2 share. Tested it with smb3 share and same.
    I have gave it almost up.
    Edited once, last by Lucky133 (January 28, 2025 at 10:17 AM).
    Maby try to set your device in standby? Did you test that already?
  • Standby no difference. "Network Storage" feature always auto connects and stays connected unless
    1) VPN activated/deactivated on Android, assume due to network disruption
    2) Server hosing SMB reboots or loses network connection (rare but indicates same issue)
    To me both indicate when network is disrupted the "Network Storage" feature loses connection and does not attempt to reconnect.
  • Images and steps.
    1. Reboot Formuler, network storage connects automatically (storage icon)
    2. Open VPN and connect, get error on network storage
    3. Network storage icon is gone, does not reconnect automatically
    4. Go into Network storage and click mount, connects no problem
  • Same here with Z11 Pro and NordVPN.
    Caused due vpn.
    Box makes connection with nas.
    Box makes vpn connection.
    Disconnecting due connection to vpn.
    But doesn't reconnect to nas.
    Manual fix is to reconnect it yourself.
    Formuler can make a fix like: connect to NAS after 30 seconds or after booting. Within the 30 seconds the vpn is already connected, after 30 seconds that the box connects to nas.
    Just a delay for nas connection.
  • Possibilities:
    Is possible that the assigned VPN IP mirrors your local IP space and is conflicting ? Usually VPNs are in the 10.x.x.x range whereas home networks ahve 192.168.x.x private space.
    Is VPN is configured for split-tunneling ? Formuler box sees two different paths for the same network address range. It gets confused about whether to send the traffic through the local router (to reach the NAS) or through the encrypted VPN tunnel.
    bonggo
  • Possibilities:
    bonggo
    You must choose with a vpn always fastest server or gome country if bo restrictions there.
    VPNs have much ip addresses. Not 10.x.x.x and 192.168.x.x that are local network addreses.
    I think you need connect first to an country. Mostly you see then an ip address other that your home router has normal.
    Nas is local network right?
    So splittunneling it. Faster network speeds.
    Edited once, last by Lucky133 (November 29, 2025 at 10:08 PM).
