Hello geeks I have problems recording programming closes mytvonline. never changes channels automatically? I also have problems opening my equipment connected in hdmi cec the z11 pro max comes out of standby mode and the tv and the sound system opens and closes immediately. all these problems that I did not have with the z10 pro max with the same equipment. I did a factory reset which did not change anything! thank you for your help
recording schedule crash and closes mytvonline3
- Z11 Pro MAX
- MYTVOnline3
rigo -
January 30, 2025 at 3:05 PM
Hello again, I also had a crash when updating, can someone help me? Thanks!
Is this new box, because that are to much issues happen on your side?
Do you have maybe power adapter with same specs like original adapter to test with this?
Hello Sam. I bought it before the holidays and it worked well at first, the problem seems to have started with updates? I took it as normal that it was not up to par. I don't have another power adapter. I regret giving my z10 pro max to my son
Sam I downloaded and installed the Android TV version directly from nordvpn could this be the cause?
Do this steps first.
1. Disconnect everything from the Box and do factory reset.
External Content www.youtube.comContent embedded from external sources will not be displayed without your consent.Through the activation of external content, you agree that personal data may be transferred to third party platforms. We have provided more information on this in our privacy policy.2. After first setup, do all updates.
3. Set MOL3 and test but without any USB devices or installed apps. If all works fine.
4. Format your USB Stick for recording with NTFS on PC and connect, test again.
5. If all works fine, now start with app install. First one, test few hours then second.
Sideloaded apk`s from Nordvpn should work but like everything also that one can produce issues if something is wrong or not installed correctly. So yes, good possible. Therefore clean factory and the steps above to find the issue.
NordVPN from Google Play Store works perfectly on Z11 Pro Max.
Display More
Thanks Sam I will do the tests
Display More
I can't find where to put the pin for the reset on the z11 pro max? what format to use with apple mac for formatting usb key ?
Reset is in the bottom of the IR hole and you need something wider than a pin. I even had problems trying to use a paper clip.
can you show a picture because i don't see where to insert the pin on the z11 pro max!
The eye extension opening is right next to the power connection(see also Gallery Z11)
I'm probably blind
but I can't find it
Inside the IR Rec hole - is also properly shown on SAM's video in post #6
ok thanks
Hi,you are not blind,but your picture is different from the one i pulled from Gallery (see Dashboard)
The hole you need to do factory reset,in your case is the IR.Rec hole(TO THE FAR LEFT)
How old is your box?
it's good i found it is located in the bottom of the IR connector. i bought the box in october 2024. thank you all for your help. i will test and i will give feedback. thank you
So, i think you have the z11promax/BT1 edition, layout on the back of your box has changed fom my z11 pm from october2022,therefore the confusion.
Hope the steps suggested by SAM will resolve your issues
feedback, thanks for your help my z11 pro max is finally behaving normally. Thanks
