I activated the xcam and put the cline of my Duo2 with card tvsat -srg and work perfectly.
I do not like that I can not edit the [lexicon]settings[/lexicon] externally.... and i hope the good 175N can make work the [lexicon]settings[/lexicon] that I've attached (G_mot_usals.zip).
S Turbo - Launcher doesn't response after Channel List upload
- S-Turbo
freddy76 -
November 5, 2017 at 1:56 PM -
I see this atthacments...
have read the bytes wrong with kb though but the 2 files are different! -
the different on the previous page file....
Nice to hear your box works again but i should wait for Formuler tool (for others) that will come this week, if you take all files you find in web and use this, then you can at end damage your box more then fix. How ever, is decision from each User how to proceed. Tools and files uploaded from me, comes always directly from Formuler.
I agree perfectly with you but I could not wait. I hope I no longer need to look out of this forum.
Is online the firmware 148 patch? -
SW 1.4.8 is still available trough OTA.
Downloaded in my decoder!
Formuler found the reason for LNR Issue and released how to and new update file for manual factory reset. The reason for not working boxes was corrupt DB/Channel List.
With next FW Update will the LNR Issue be resolved.The complete how to and needed file you can find here >> S Series Instructions / S Serie Anleitungen
i have test it on my defect STB and not working ,box is without update. After time on screen is inscription "Launcher without reaction"
I forgot ,my box is Smini
The Factory Reset Tool is already avaliable o manufecturer's web site formulert.tv https://drive.google.com/file/d/1m32UcG…iKjhnwPI02/view
My S Turbo is back to live again. I hope they solved the issue... -
It`s same like here in Instruction Thread and Database, since yesterday
'Well done to SAM and Formuler as they have uploaded the latest S Series rescue tool for 'launcher doesn't respond issue'
We have repaired the S Mini's and S Turbo's.I have added steps 8 to 11 that may help you guys with progress bar not showing when performing a rescue.
Instructions:
1. Check update.ird file integrity before proceeding
2. Copy update.ird to USB root
3. Power off S-Series device
4. Insert USB into S-Series device
5. Power on S-Series device while repeatedly pressing the CH-UP button on the RCU. (Don't hold the button down. Press it repeatedly)
6. Update progress bar appears on the screen. Stop pressing the CH-UP button
7. Wait for the progress bar to reach 100%. The device will reboot automatically when finished.
8. Note: If first attempt fails to perform a rescue (no progress bar) power down the device and check the USB pen on a Windows desktop or compatible iMac. You may find default folders have appeared: Android Folder & LOST:DIR.
9. Delete Android Folder & LOST:DIR from the USB and keep the original update.ird file.
10. Remove the power cable from the rear of the device and reinsert the USB to the rear of the S Series device again.
11. Reinsert the power cable and continue with step 5 onwards. -
after last update and automatic reboot, sytem no work, boot and stay always on LOAD on display, rescue tool no work - i see updt on display, progress bar is workiing till 100%, reboot and LOAD on diplay again
. WiFi keeps disconnecting2. The launcher crashes once connected to the LAN Port.3. I'm not sure why the VOD section is giving problems with playing movies.4. Does the PIP mode on the remote work.5. loading issues within the MOL app.7. Delay with populating the epg guide quickly when pressed.PLEASE CAN YOU ASSIST
Hallo.just change launcher to clasic. I have the same problem. sorry for my English
hola llevo unos días con este problema
el iniciador se bloquea y tengo que decenchufar la caja para que vuelva a funcionar
el firmware es 1.5.0 -
Hi, I've been with this problem for a few days
the initiator is blocked and I have to de-plug the box so that it works again
the firmware is 1.5.0 -
The spez. issue what for this thread was opened (no boot after install of faulty Channel List) is already fixed with -> Formuler tool. Optimisation was done with Update 1.5.0 and 1.5.2.
The last postings with no boot problems is other issue, please -> read new thread.Thank you for your understanding.
Thread closed. -
