I have two different servers that get stuck at 89% for a long time. I reduced the number of groups(channels) and still the same. I tried the same servers on the mobile app and other devices and connects right away. Also on Z11 mytvonline 3 it connects right away. So the problem is definitely with mytvonline2 on the boxes.
Mytvonline 2 Stuck at 89%
- MYTVOnline2
- Z 10
nibs -
September 30, 2025 at 9:20 PM
Reinstall portal and put again your login data.
So in connections delete the portal and add it again?
Yes, i guess you use XC APi? First restart the box once and be sure the sub. with same data is not used on some other box when you connect.
No most are with mac address.
Also this happens with brand new boxes, I add the portal for first time and gets stuck at 89%.
So I tried deleting the portal and adding again, restarted the box and same thing stuck at 89%. Then I changed the account from mac address to m3u and it connected.
OK Stalker Mac/ID, tell provider to refresh your sub. and registered mac.
But why its only happening when using z10. When I change mac and try on other device like z11 it works. Also on mytvonline mobile works.
i messaged you to get more info.
Please check your inbox
Code
Hi everyone. I'm new here. I have a Z+ Neo at home that I had to reset. Since I tried reinstalling the software via USB, MOL2 hasn't been opening some of the series' servers. It has nothing to do with the server, as my Z11 Pro Max works fine with the same line. Does anyone know how to help? Thanks for help -
Code
Hi everyone. I'm new here. I have a Z+ Neo at home that I had to reset. Since I tried reinstalling the software via USB, MOL2 hasn't been opening some of the series' servers. It has nothing to do with the server, as my Z11 Pro Max works fine with the same line. Does anyone know how to help? Thanks for helpDid you tried 3 times Refresh from mytvonline 2 menu?
Please check with the new beta update that just released.
Access Code: 1339
1. Open the Software Update app
2. Enter the appropriate access code, then press the red box button
3. Start Download
