Hi everyone,
I recently bought the Formuler Z12 Ultra and ran into a pretty serious issue.
In MyTVOnline, the regular info bar shows 50fps when switching channels. That would be great – but when pressing the Info button twice, the extended info overlay in the bottom-left corner shows the actual framerate, and it’s consistently only 25fps.
The picture confirms it: motion is clearly choppy, with visible combing effects. It looks like MyTVOnline simply does not perform deinterlacing, even though the stream is flagged as 50fps.
I’ve tested multiple portals, different settings, different channels – same result every time.
So my question to the community and the Formuler team:
Is this a known bug? A missing feature? Or is MyTVOnline on the Z12 Ultra really not doing any deinterlacing at all?
Right now, live TV is basically unusable for anything that should display 50fps smoothly.
Any feedback or clarification would be appreciated.
This issue urgently needs attention, because the box cannot deliver proper live TV in its current state.
