Last update youtube not working
Youtube
- MYTVOnline2
- CC
matrixpitt -
January 11, 2026 at 6:32 PM
Delete last update for YouTube if possible.
Or try TizenTube.
Youtube, but without c*mmerc**ls.
https://github.com/reisxd/TizenTubeCobalt/releases/download/v1.0.6/cobalt-arm.apk
Put it on usb and install. I hope it accept the android version.
Or try TizenTube.
https://github.com/reisxd/TizenTu…/cobalt-arm.apk
I installed TizenTube from Formuler Market,works fine
Was that the one who couldn't update to version 1.0.6?
Dont know,it appeared in january 26 for the first time in Formuler Market,so i rely on it being up to date,up to now it works fine,no updates appeared yet
Just hold ok button on icon and go to info. Check version above
Info is vs 1.0.6 tizentube.
Or try TizenTube.
Hi!
In last software tizentube not working
Hi!
Hi,did you try install from Formuler Market,on my side TT is working.
Tizentube installed today from Market and this works very well.
Hi!
Please access android settings > apps > security & restrictions > unknown sources > Install unknown apps > and make sure TizenTube is enabled.
