That is a problem, because if the remote control stops working, I can no longer access the menus.
Also when unpaired,so IR mode?
Here is the guide to send the logs via USB file. You can send it to me via email @ [email protected]
💡 HOW TO
That's easier said than done
I'm doing my best to reproduce this.
Were you able to find anything, Peter?
would require dumplog to find anything for this case.
I sent you an email on 13-04-2026. Apparently, it was not seen. I have just sent another email with the log files from the email address I use to log in here.
could you let me know your email address? I receive hundreds of emails and it is hard for me to track.
PB
I have upgraded since a long time (when it came out) and the problem with VOD and TV-showes crashing started today!
Problem with Z11 Pro Max, when I'm going to VOD or TV-shows it automatically goes back to TV-Live. So it's not possible to watch VOD or TV-Shows anymore. I cleared the cash, taken out the power cable, but nothing works. Maybe an update are necessary, it was a long time there was an update for Z11 Pro Max.
First, try a full factory reset, and format your external usb device to ntfs
So you're not coming with an update to fix this then?
And don't forget to make an backup of mytvonline on a usb.
So you can simply restore portal(s), settings and favs)
I'm not coming with anything but my wife, i'm just a customer like you
Good morning to everyone
I have the same problem since today as soon as I switch serial or vod the mytvonline application restarts. Bizarre this problem.
PB
PM ![]()
Just a quick update: I now have 12 customers who have removed their Bluetooth connection and are now operating the box using only IR. All of these customers are complaining that the remote control can no longer 'transmit' to the box when using Bluetooth.
PM
couldn't find much information from the logs you have sent. Do you have some pictures of the BT1 remotes?
That is really a shame; I was really lucky when the problem occurred again in my test setup and I had logging enabled.
They are all the standard "BT Universal" BT remote controls. These are included with the Z11 Pro BT edition.
I'm not coming with anything but my wife, I'm just a customer like you
No good deed goes unpunished. ![]()
