Factory reset Z+
  • Hello, I am a new user. I have a question. I received a z formuler z but the previous owner put a parent code. I do not know how to set it in factory reset. do you know how I can reformat it? is there a manual firmery pear device? Thank you for your answers.
  • You can do a manual factory reset to return the set to factory state.
  • Changed the header text for better recognising.
    No, the process is not same because of different Android version.
    Use following instruction/s:
    Changed the title of the thread from “Factory reset” to “Factory reset Z+”.
