Formuler z7+
  • Hello. Since the last update , my z7+ poweroff alone After 1h when i don't touch remote......when a See a movie .
    Does this always happen exactly 60mins after the movie starts?
    In other words, is the problem reproduced every time?
  • before the update, I received the message asking me to press o.k. to not go into sleep mode. but now since the last update, no more message. the z7 + automatically turns off.
    Thanks for the additional info.
    The Inactivity Timer should not be active while watching VOD movies.
    Will forward your report to the engineers.
  • hello is it possible to disable the automatic standby if not used . Thanks
    This is something controlled by the portal provider.
    Please ask them about it.
    Some providers enforce the playback limit and some do not.
  • In Mytvonline Settings menu, check the value for Playback Limit. It should be set to "OFF"
    If you don't see "Playback Limit" your portal provider is controlling the value.
    Closed the thread.
