Anyone having audio out of sync with video issue on some channels but most channels work in sync?
Any fixes?
Any fixes?
Did you check your output of sound?
you can check it as below.
[setting->android->sound]
CBP ADM,
Thanks for the comment, but not the issue.
Bekomme keine epg daten in meinen formuler7z
same here. Since 4 days i don't get any EPG data
Also some channels are out of sync with video and audio
My EPG is good.
My only issue is audio out of sync with video on some channels. #38 Paramount is the worst for me.
Same here for me a couple of channel's are out of sync with audio
Bobbybacala,
My issue is with one IPTV provider, my other one has no out of sync problems.
Hi All,
I find out that i have 1 channel thats out of sync. but when im look for the channel i find it also at a other country, and that channel is in sync.
Maybe you can search for same channel in other country?
Bobbybacala,
its a mytvonline bugg. I tried with STB emu and it was fine then switched back to mytv and it was out of sync. Went into Facebook group for my IPTV provider and they said same thing
Having the same issue with my former z7+ using ****** IPTV service. No sync issues using the Perfect Player App with ***** so definitely an issue with the Mytvonline formuler app.
Having the same issue with my former z7+ using ****** IPTV service. No sync issues using the Perfect Player App with ****** so definitely an issue with the Mytvonline formuler app.
I have the same issue using the same provider
as I understand Formuler support didnt read this forum.
Made my account here just to post about the same issue. Kinda glad to know it's not just me.
There working on it
