Custom display format
  • 3840x2160 is 4k! In resolution window shown as 2160 /50 or 60hz.
    If you mean 4k2k with 4096x2160, this is now only visible on tv's that can work with this resolution.
    Changelog: [SYSTEM] IMP: Display resolution selection window only shows compatible resolutions
  • Hopefully this helps to understand 4K,
    4K refers to one of two high definition resolutions: 3840 x 2160 pixels or 4096 x 2160 pixels. 4K is four times the pixel resolution, or twice the line resolution (2160p), of 1080p (1920 x 1080 pixels). The other high definition resolutions in use are 720p and 1080i. These are the resolutions most frequently used in larger screen televisions to create better detailed pictures.
    4K resolution is used in commercial digital cinema using the 4096 x 2160 option, where many films are shot or mastered in 4K by upscaling from 2K (1998 x 1080 for the 1.85:1 aspect ratio or 2048 x 858 for 2.35:1 aspect ratio).
    Under its two official consumer labels, Ultra HD and UHD, 4K is well established in the consumer and home theater landscape, using the 3840 x 2160 pixel option.
    Credit : by Robert Silva,
    Updated March 26, 2019
    HOME THEATER, Livewire website
