I have 2 different lists and also an epg links... in Smarters iptv app ... EPG works but here in My tv online 2 not.
I don't know where is a problem ? Anybody know ?
How are you connected? Did you try to connect through xc api?
Do you thing a Portal link ?
xc api url:
user/pass
This is just an example. In your case it's different. You can find this in your m3u link.
Example:
htp://xx.xxxxxx.xxx/get.php?username=xxxxx&password=xxxxx&type=m3u_plus&output=ts
Hope this helps.
Yes i have a link like this..
So what is wrong ?
Use the XC api I just posted and type it in your portal, but use your url user/pass from your link instead.
Now it works with the m3u link... I found out that the program takes 10 minutes to show the EPG ... How do I refresh the EPG?
I would use xc api. I have found that the epg loads a lot faster than m3u.
i hawe only m3u a long link...with passvord and username... have it looks like link for pc api...(this is the 1. one ) ?
Ok i get it from provider and then apload to 34 % and then error kode 7 ????
34%, something is wrong with entered url, check the url and type again.
O have problème with EPG on MYTV ONLINE2 to! What can i do to résolve this?
Epg dont works!!!
Epg dont works!!!
Calm down.. Provide more info, how are you connected?
Im connect with m3u url with somthing like this ar the end “ plus&output=mpegts”
And in the second server is “ plus&output=ts”
Try to connect through XC or mac adress, here is an example for xc:
xc api url:
user/pass
Example:
htp://tv.server.com/get.php?username=XXXXXX&password=XXXXX&type=m3u_plus&output=ts
Hope this helps.
But if you still want only to use your M3U Playlist, you must do following.
1. Connections -> Your Playlist -> and insert 2. into "Playlist XML TV EPG URL
2. h t t p://your-provider.com/xmltv.php?username=XXXXXX&password=XXXXX
*h t t p in url insert as http!
I still have the same problem EPG does not work ... I have a longer m3u http:// ...... username&pasvord plus &output .... list where to subscribe to the 1st option ...portal? or 2nd ?
Did you read my post over yours? Read again carefully, take needed from your existing URL and create epg url like in my post.
Finally, I've figured out how to do it Thank you 😆
Thank you for your help! It works!!! 👍🏼🙏🏼😉
Epg works but just can ser today, i cant see epg for other duas, it is normal?
Hello, my EPG list stop working aswell today. (MYTVONL2 )
Few (really few ) shows epg others show ( New epg ulr,plz visit our website) and the rest > NOTHING.
I went on my provider site,no info about epg anywhere.
Connected with URL (no username or passwords ) ( no m3u) just with registration with server operator.
Before contacting my provider maybe someone had something like that ?
