Hi, I'm considering buying the formuler s turbo.
Would anyone be able to tell me how long it takes to go from the box being on standby to live tv?
Also, is that time the same across the formuler range?
Thanks ![]()
Thanks ![]()
watching DVB or IPTV with Mol?
Hi thanks for you’re reply, can you provide the time for both? If possible please
Watching dvb go into standby and back to live dvb, 2-3 sec. But note, depends also from tv if already active or not and on right hdmi port. The box is very fast in this case.
Mytvonline app for iptv must be executed from home menu. Menu pressing, choosing app, execute, connecton to provider (loading time depends how big the channel list is, shorter list means faster connect), between 7-15 sec.
If mol programmed on rcu button, then you get faster start. With active processes and app's in background you can switch between them very fast.
Great thanks. So if you turn the box to standby while watching via MOL and turn it back on, it’ll go to main menu?
Anyone? ![]()
No, it will continue from mol or where you left it. It just wakes up again. Standby mode - sleep mode.
Ok nice! Last question, I promise.... when it wakes up after you’ve left it on mol, does it take a while to connect to the provider or would it be nearly instant as with DVB?
Mevi, on Z but not on S.
On S Turbo should the box start with dvb after standby, it is still dvb box and have this priority. You can change this if you program mol as starting app, then it`s similar like mevi say.
I see you are speed junky ![]()
If App is active in background and the connection with provider is still a live, then yes. If not, the connecting depends from your network, isp and provider. In most cases not longer then few sec.
Hope all questions are answered now ![]()
Didn't see it was for S. Unfortunately I have no experience with the S series. Never owned one.
NP, with so much boxes here, everyone can to interchange something. Happens to me also sometimes ![]()
Thanks guys
