After installing the newest update my iptv is showing code error 7. Contacted the provider as he told me that my ip gets blocked frequently. I never use same account on two devices. Only on 1. This happens only on Formuler devices.
Error code 7
cliftin -
July 23, 2019 at 5:04 PM -
Maybe try m3u
This is another case of the Z8 causing IP blocking with "certain" providers....
dreamer
I am also having this problem. I then downloaded the m3u again and it loaded up but everything is just a black screen.
My guess is you've been IP banned...check with your provider
dreamer
dreamer
Just played around with it more. It seems I was on some Canadian channels and they have been having problems with. I switched to some american channels and everything was working fine.
I noticed my provider had changed the m3u link/address up. Make sure your using the correct link when you have the code 7. I deleted my connections and re-added them.
It has just happen to me in NZ - I have a Z7+ and Z8 and I'm getting the Code7 - I now have to use vpn
