I think this relates to the new update. Basically the ability to turn volume up and down works for some channels but not others with same provider. For those channels where it doesn't work I can mute the channel by turning volume down as far as it goes. But cannot adjust volume on these channels if that makes sense. I've run into this in the past a little and adjusting Android sound settings has always fixed it but not this time
Controlling TV volume
Install Audio Optimizer from the Market and try again
Did... gave me message, "audio already optimized"
what is shown in the audio track selection menu?
Live > options (red button) > audio track
Two options
Eng (ac3)
Auto
Both do not fix issue
What is set in Android Settings-> Sound -> RAW or LPCM? Change to LPCM and try again.
Sam
Fixed! Thanks
