What is best wireless keyboard & mouse to use? This remote stuff inputting URL , PW is getting old now & very time consuming.
Wondering what you Formular Z8 uses are using.
I use my phone.
what you mean you have a app on your phone to use as a keyboad for Formuler or smart TVs?
For Formuler.
how & where?
For android is an app in de Playstore
Air sync remote
The "Android TV Remote Control" app (by Google LLC) also works well.
i will try this.
Thx for info.
Yes I'm using that app with iOS.
How to do it on ios ?.
On iPhone?
On iPhone?
Yes please
Yes please
Just download the Android TV app from the Apple store.
Will try ,thanks
People who want to use Keyboard and mouse, there are also two really good alternatives.
1. RII8 mini with keyboard and touchpad or
2. Programmable Orbsmart RCU with air mouse and keyboard on backside.
I have both and don`t want to miss them. Apps are always ok but such RCU with all incl. is something else and much better.
When I bought my Z8 it came with a mini keyboard that uses a USB FOB. I plugged it into the USB2 on the Z8.
yeah mine came with that extra glow in the dark remote.
