The question has already been asked but I can't find it anymore.
How to record a channel and watch another.
my connection in the portal looks like this example.
I don't know how to do it.
thank you
thank you
didnt work with stalker/Mac Portal!
Only XC Api supports this, Stalker MAC/ID not possible.
Please post again and continue in English!
Sorry my translated browser without my permission.
before the update, we had access to VOD during a recording. Now this is no longer possible. Why?
Read this posting -> RE: Official FW 1.4.65 - SW 7.8.5 for Z8/ZAlpha (21.05.2020)
shame, thank you for answering me.
hello, I allow myself to insist because I do not understand something.
There are 3 types of connections
M3U
MAC
Xtcodes
MAC and Xtcodes are recognizable like this ==>
MAC URL: http://the.server.com:port/c
Xtcodes URL: http://the.server.com:port
I use an Xtcodes connection, but despite that I don't know how to record a channel and be able to watch another.
Can you help me.
thank you so much
For this feature you need two connections/lines in one sub, with single connection it`s not possible.
Here more infos to understand why.
The user assumes any risk of ban in this case! This depends fully from your provider and permission. Formuler is not responsible for any bans in this case. Pleas check this first with your provider before you use this feature with your m3u playlist.
Is merge possible?
