Anyone use it on their Z8?
Curious to know how many screens you've managed to play at the same time in multi-view.
I'm not having much success in anything above split-screen.
It's a good app but quite worthless if not purchased.
Yes i tried it after someone posted a question . I wasn't prepared to pay when you couldn't see what it was supposed to do and if it did it.
I bet it puts a few off
PLUS Mytv is far better from the limited preview they give IMO
it is a very good app actually. I decided to pay the small 1 year subscription price to have a decent look at it. Extremely customizable and performs very well. I am now running one of my services through it to test it out properly. Still run one through MOL2 which is obviously fantastic,, but it is always nice to have options.
Sure, why not
I use Tivimate for Tests and compares, working and not working subs.
I paid for a subscription and the multi screen view works awesome on my fire stick and fire cube but when I try to do picture in picture on my Formuler Z8 1 screen blacks out so I can only see one.
That's to do with decoder settings within Tivimate. Need to change from hardware to software, but can affect quality of streams.
It work but video like you said total garbage. Why does it work on firestick
I've used it and liked it a lot. However I'm still with Mol2 as it is also easy to use. Tivimate is easy to use AND you can adjust your favorites very easily. JMHO
I like the tivimate pip just doesn’t work at all have to change video codec
Tivimate 3.0 update is very unstable on my Z8. Freezes picture and black screen when using "back button". I like it as an option from MOTV2 due to the ease of organizing Favorites.
The only problem I have experienced with tivi on the Z8 is with multi-screen. Everything else works flawlessly and an extremely good alternative to MOL2. Might be something you can do buddy. I did make a few tweaks to mine. It is very customizable.
I cannot get Tivimate 3.01 to pla,y nicely with formula z8. lots of freezing and black screen when "go back or search"
