Getting message app is no longer supported...check with developers? Apk version of app and will not upgrade. Any answers?
ITV hub
Hello, install aptoide tv from the market, and install the latest version of your app from aptoide tv
Same outcome I did that
itv hub works fine for us. One of the most used apps on our box actually (not by me personally 😁) . Had box a year or so and installed from playstore when it was new and have never had an issue with it.
Just trying to use the itv hub on my Z8 and can’t work out how to scroll the screen down?
Can anyone advise please as it seems to be optimised for a phone screen where you can obviously swipe the screen to navigate.
You would need an air mouse / mouse.
Give me chance to install it LOL..
I can't seem to do anything with curser arrow or tab I'll keep playing.
The only work round was to search for program required
Is it at all compatible with box pic quality awful and everything take an age. Mrs says it works well on TV app
Yeah unfortunately uk catch up type apps are better on tv smart hubs and certain main stream brands, due to operating systems and certs.
If you use Kodi, then Iplayer and ITV hub in that is a better work around, but alternatively as you say just use the tv based apps. -
I only loaded to test for post #4 glad I don't want it>
