HDMI output hardware/software failure after 3 days of use
  • Hi gang,
    I've had the GTV for 3 days now (UK version) after the initial supplier delay.
    It is a fantastic box, I set everything up correctly, installed the initial 600mb update and the rcu and mtol2 updates and been using it without any issues whatsoever.
    But I believe the hardware/software may have failed today after 3 days of moderate use :frowning_face:. No output is being delivered to the TV.
    1. I had the unit in sleep overnight with the red led on, prior to which everything was fine.
    2. Turned on the unit this morning with the led changing to white.
    3. No output on the tv, default tv message saying no signal however the tv could detect that the HDMI port was connected to a device as it was active.
    4. Turned off GTV power and restarted the device. The LED turned white but again no output on the tv but tv could detect some HDMI source is connected.
    5. Thought it might be a bad cable or the TV. Changed the HDMI lead 3 times and tried connecting to 2 other televisions but the same result.
    6. Left the box unconnected without power for a few hours and tried again on 3 different TVs again but with no luck.
    7. GTV seems to be responding to key presses on the remote as the white led does blink but only when pointed to the unit - so only via IR and not via Bluetooth. Have no idea if it's doing anything on the OS or not.
    Something really fundamental has gone wrong here in the unit and I have no idea why this has happened. As a user, I should never be in a position where I'm left with what feels like a brick on such a premium flagship device under normal intended use. It feels like either the HDMI port has failed or a software issue. But I could be totally wrong.
    Can anyone help? I cannot even do a factory reset as there is no video output anywhere and no buttons on the device to perform a reset.
    As a sidenote, I really think there should be an easy way on any device in this league to allow a user to factory reset their device without relying on software. I'm in touch with my supplier and awaiting next steps and really just want to have a unit that works.
    I was so impressed with this unit over the weekend that I ordered a second one for the other room and then this issue happened this morning ¯\_(ツ)_/¯
    I hope I didn't jump into it too quickly by getting a half-tested product. I appreciate that there are always teething issues at launch but this is really bad timing, it's holiday period, majority of UK is now going into tier 3 lockdown, and IPTV is all I have 😭 and this is not the best time to be ironing stuff out. Anyone heard of code/change freeze 😬?
    If Formuler want to have this unit to debug or retrieve logs or anything that may help them find this issue before it affects others, feel free to message me.
    Any advice would be appreciated.
    Edited 3 times, last by Chipmunk19 (December 14, 2020 at 11:02 PM).
  • You mentioned you got the box after initial supplier delay?
    I trust you may have got this from W.O.S as they’re the UK distributor...
    If so, reach out to them and advise the issue, they’ll likely ask you to return it for replacement.
    It seems evident it maybe a device fault if you’ve tried it on another tv and with different cables.
  • Hey greenfordraj,
    Thanks for the suggestion. I actually came across that article but it's not for GTV or Android TV OS which feels like a totally different ballgame to Z series on AOSP. I'm hesitant to try anything from other devices incase I make the situation worse or hard brick it if it isn't already in that state.
    This is another annoying point around the launch and support documentation. There is absolutely no support material on the Formuler site for this model. Again questions arise, why wasn't such a common reset procedure for GTV part of the docs before the launch. Everything around this device feels rushed.
    Apologies if this is a bit of a rant but this really isn't expected from a premium, flagship device.
