Hi!
Is it possible to add more channels to preview on the Home Screen? Can see a few of my streaming channels today but not all and would like to be able to add them...
Thanks!
Hi!
Thanks!
Nothing? Is it not possible to add channels?
If you mean via MOL2? I think it's just currently what it is at the moment via home screen app / preview row.
It’s only used to view the most recent channels up to a certain amount, no need for anymore because by the stage you’d be better opening MOL2.
It is Android TV feature, shows preview from (in case of MOL2) max.16 channels. It was not programmed to watch live TV for longer, just preview.
Ok. But is it possible to add more services (ie. Spotify, Youtube, Netflix etc)? If yes, how? 😎
Thanks!
Market Place
Market Place
There is no Market on GTV.
I believe he is referring to adding to the Home Screen on GTV, not where to find the app.
Thanks!
YouTube is possible and Amazon Prime and YouTube music, YouTube Kids.
2 ways to add them to Home Screen on GTV
Method 1) on the Home Screen where you see your current apps, press down on the remote control until you see “customise channels” and select that
Method 2) on the Home Screen, go to settings > device preferences > Home Screen
OK cheers I still don't have one,
I've been steering clear of GTV questions unless they sound familiar
General top top for GTV users
If you’re within an app such as YouTube or what ever.
Instead of pressing back button to exit the app so you can open MOL2
Simply press the remote control button at the bottom with 4 dots and it will open MOL2 and override your other apps.
That was for me set as default in RCU setup however if yours isn’t, you can set it as a hot key using the remote app.
Thanks.
Yes I know of the methods. But the question is if I can add programs that I cannot find in the list? Can I add any software?
Why not give it a go and find out.
Download Spotify from Play store and see if you can add it, you might be pleased with the outcome
