How do you clear the cache on a formuler Z7+please?
How do you clear the cache on MOL1?
- MYTVOnline1
redrooster -
November 9, 2019 at 5:37 PM -
For what exactly, MOL1?
Well the cache in an app I am using specifically as the app is not working properly and I was told by support to try clearing my cache and data?
Factory reset
Go to Main screen, select on left bottom Settings.
Then on the right side Apps.
Select the app you have problems with and then clear cache.
Clearing Cache and data in MOL1:
1. Home Menu -> Cog wheel
2. Android
3. Apps
4. Mytvonline
5. Storage
6. Clear Cache + Clear Data
Uh now I know what "MOL1" is, My To On-line but that is not the app I am having trouble with it is OK3 app.
However I tried above solution and it worked. Thank you for the help Sam.
Of course, clearing cache and data how to, works also for all other apps.
will this clear all user data including line data, favourite folder?
Data clearing means deleting all included text and settings from this app.
