🎉 Celebrating 4 years of Software Updates 🎉
New Hotfix release is out now. Please update again.
Formuler Z, Nano, Prime, Plus, ZX, Z7+
MYTVOnline 1 : 2.0.3 HOTFIX
Install and use at your own risk.
Change Log
FIX: Cannot connect to some portals
New update released for Z prime <> Z7+5G.
Firmware Version : 1.3.2 for Zx, Z7+, Zx 5G and Z7+ 5G
Firmware Version : 2.9.2 for Z prime, Z, Z+, Z Nano
MYTVOnline : 2.0.2
Important: Install and use at your own risk. Software cannot be rolled back after installation.
Change Log
Firmware Version : 2.9.2 or 1.3.2
Fixes & Improvements:
- FIX: Certain apps can't be started from the home screen
- FIX: Automatic System Date & Time bug
- FIX: Android Settings > Languages & input > Virtual keyboard > RCU d-pad keys not working
MYTVOnline : 2.0.2
- ADD: Main Menu > Recordings, Exit menu items
- ADD: Main Menu > Settings > EPG All: On/Off. Choose to download the All EPG package or not
- IMP: Press and HOLD PLAY to start Cloud Timeshift. No need to press INFO button
- FIX: Problem connecting to HTTPS portal
- FIX: Long loading times for VOD and Series sections
- FIX: Problem with some m3u and xmltv URLs
- FIX: Can't view VOD > All group
- FIX: VOD Player > subtitle end-time issue
- FIX: Series loading issue
- FIX: HTTP Request header issue
