Why does my Z8 disconnect from WIFI on its own (excellent reception of WIFI) and reconnect a few seconds later without stopping ???
Video : https://www.dropbox.com/s/ftln9g2utjdf…132653.mp4?dl=0
Restart Router and the box.
Done / no change
Ethernet cable connected or disconnected?
WIFI only (no cable)
Click on your SSID (ChevaldAcier2) and in next window on "forget network". Restart the box once, search for your wifi again, type password and connect again, click on your SSID again and in next window chose IP Settings "DHCP" and confirm dhcp again.
If all of this doesn`t help, then have something changed in your Router (Firmware update maybe?) or you need to do factory reset on your box as last solution.
Try also with static ip.
Uninstall any VPN or DNS apps. Check your router firewall settings.
The "!" symbol doesn't mean the wifi is disconnected. It means the "check connection to outside internet" test has failed.
When the "!" symbol is shown, try to open Youtube to see if it works. If it works, your router, VPN, DNS is blocking the internet checking DNS, but it doesn't affect anything.
Everything has become OK ...
Do not ask me why because I have no idea ... Anyway everything is now OK
Thanks for the help
Aliens on the roof and now take of? ![]()
Must be this magnetic interference thing ![]()
Hahahahaha ![]()
